Laub auf dem Innenraumfilter? Ist oben kein Gitter
Heizungsgebläse quietscht
Doch, da ist eins. Sieht man auch wenn man die Haube aufmacht. Ich parke leider unter Bäumen das ganze Jahr. Ich entferne die Blätter im Herbst auch regelmäßig. Beim Mokka sammelt sich da so einiges an, die Rinne vorne ist ja auch tief genug. Aber irgendwie schaffen es immer ein paar durchs Gitter. Frag mich nicht wie.
Moin, moin,
mein Lüftermotor wurde im Rahmen der Garantie (3 Jahre) vom FOH getauscht.Gruß
Ulli -
I have the blower motor chirp problem too. Found this on another forum. Will probably try it out later on.
Originally Posted by tasz
Hey guys, 2008 tacoma and been making noise from the cabin fan for
the last two years. took it to the dealership multiple times till i got
fed up and fixed it my self. every time they just oil the bearingsread the forums and greased the bearings front and back. This made the noise go away for a while and then it came back again.
The reason for the squeak is the brushes that ride on the motor
shaft, that is why it ticks every revolution and the fast it turns the
faster it ticks. if you remove the fan and then take off the metal back
cover of the motor it will expose the brushes (carbon pieces with the
springs behind them that are wired to where the electrical connection
plugs in.)The reason that all the previous suggestions work for a while and
then come back is because you end up adjusting the bushes slightly so
that they dont make noise but eventually it wears back in and ticks
again. The same thing happens when you get the blower replaced under
warranty. It will be quiet until the brushes wear in all the way around
the motor shaft and the edges start to catch, making the ticking
sound.To fix this, remove the brushes from the motor and use a file to file
off the leading edges of the brushes to a 45 degree angle. the brushes
are very soft and this is ease to do. reinstall and put back into
service and you will have silence finally.I almost sold the truck I was so annoyed with this but silence is
golden. I actually had to hit the switch the other day to see if the fan
was on because i was just so used to hearing it all the time.good luck and there are pictures of the brushes in the first post on this forum which show them very well.
Hey guys, 3 months now and all still quiet. This is with the fan running every day.
To get rid of the noise i filed the leading edge of the brushes and i
didnt write it in the first mail but i actually filed the back edge
also. I would say that i filed it to a 45 deg angle about 1/8" to 3/16"
down and then also streached the springs about an extra 1/4" to put a
little more force on the brushes.original post Nov 16 2011
Hi Gooli,
thank you for your post!
Did I understand right? You are sharpening the carbon brushes?
Yes. As far as I can see, the leading edge is the most important one.
[Blockierte Grafik: http://oi68.tinypic.com/vqjeif.jpg]
Bei der letzten Inspektion hatte ich ganz kurz wieder Geräusche in der Lüftung wenn ich voll aufdrehte. Hat sich aber nach einer Minute wieder gegeben, klingt alles wieder normal. Scheint eine Achillesferse zu sein. Wenn das nicht auf den hundersten Millimeter wieder zusammengebaut wird scheint es anfällig zu sein.
Ich hatte am Mittwoch auch die Inspektion mit neuem Pollenfilter und Klimaanlagenreinigung.
Heute brummt der Lüfter schön und am Dienstag bin ich beim OH.Schließlich haben die das alles gereinigt und aus-/zusammengebaut.
Externer Inhalt youtu.beInhalte von externen Seiten werden ohne Ihre Zustimmung nicht automatisch geladen und angezeigt.Durch die Aktivierung der externen Inhalte erklären Sie sich damit einverstanden, dass personenbezogene Daten an Drittplattformen übermittelt werden. Mehr Informationen dazu haben wir in unserer Datenschutzerklärung zur Verfügung gestellt. -
Klingt so als käme da was an den "Lüftungspropeller"
So etwas kontrolliert man doch nach getaner Arbeit
Die Heimfahrt war ja auch in Ordnung...
