Good idea, thanks. I'll try this!
Dauerstrom elektrische Sicherheit - Mokka X
Hello, I don't know what the electrician did...
Now, on my Mokka X, the yellow (BAT) wire is on B02 (spare fuse) and red (ACC) wire is on F17 (spare fuse). If I pull out any of the wires, the dash cam is not working (either with ignition on or off). It works only with both wires plugged. This is the way hardwire kit works? It wouldn't work with permanent fuse only (BAT) when ignition off, or only with the other wire (ACC) when ignition on? There have to be both wires connected to get the hardwire kit working?
Attached fuse panel (from book and photo).
Thanks for support!* Unsere Seite enthält Affiliate-Links, für die unser Forum möglicherweise eine Vergütung bekommt.
"Now, on my Mokka X, the yellow (BAT) wire is on B02 (spare fuse)"
On B02 is nothing conected. It's a spare fuse ...
Do you can send a wiring diagram from the dashcam?
It's one wire connected!
Ok. But there is no power on ...
But, i don't know how, the dashcam is working. Should I better buy a multimeter?
The Lamp is also working well ...
But: A Multimeter is good to have and not so expensive: http://www.ebay.de/itm/262877266024
Do you think this would be ok? http://uni-trend.com/productsd…uctsCateId=749&CateId=749
[Blockierte Grafik: https://cdn-reichelt.de/bilder/web/xxl_ws/D100/UT33D.png]
https://m.reichelt.at/Multimeter-digital/UT-33D/3/index.html?ACTION=3&GROUPID=4058&ARTICLE=156076
- 14,02 €
Handliches Digitalmultimeter von Uni-T mit einer Vielzahl an Standardmessfunktionen und Zusatzfunktionen. Perfekt für den Einstieg in die Messtechnik, die Hobbyelektronik sowie den Werkstatt- und Ausbildungsbereich geeignet.
Funktionen und Eigenschaften:
- integrierte LCD-Anzeige, beleuchtet, 2.000 Counts
- Grundgenauigkeit: 0,5%
- Gleich- und Wechselspannungsmessung von 0 bis 250 V AC / DC
- Gleichstrommessung von 0 bis 10 A
- Widerstandsmessung von 0 bis 200 MOhm
- manuelle Messbereichswahl
- Rechtecksignalausgang
- Durchgangsprüfung
- Diodentestfunktion
- Batteriewarnung
- Data-Hold
- Stromversorgung: 1x 9 V Block-Batterie
- Messkategorie: CAT II 250 V
- LCD-Anzeige: 48 x 16 mm
- Maße: 130 x 74 x 35 mm
- Gewicht: 179 g
Lieferumfang:
UT 33 Multimeter, Anleitung, Batterien, MessleitungenOf course is this ok ...
Thank you. I wouldn't ever thought it would be so complicated to have a working dash cam...
